hello there,
have this evening ordered the 2" lift kit from roughtrax for my 2nd gen KZN130 (rear coil springs, front and rear shocks and uprated torsion bar). wondering if also going to need or would gain any benefit from the ordering up the following:
- adjustable panard rod
- extended brake lines
- front axle spacer
have spent a lot of time reading through various threads and there seems to be some debate as to whether or not the above three items are also required. any advice out there from previous lifters in the know?
after the lift, my surf is still going to be spending the majority of it's life on road commuting, but will have a proper play off road from time to time at the likes of close by drumclog. off road nut mechanic friend of a friend is fitting the kit.
cheers,
stew
- front axle spacer
cheers,
stew
