Hi all.
I've just subscribed as I'm the new owner of a 3rd gen 1996 3.0 auto. Silver and blue. It's the first surf I've owner. Actually, the first 4x4 I've owned.
Overall I'm delighted with it, but two things are apparent straight away. Getting the key out of the ignition involves black magic. Sometimes it moves around to 'lock' like a greased whippet and I'm out of the car and off. Sometimes I'm there for 10 minutes swearing and twisting and pushing and putting it into gear and out again. Is this normal ? If not, is it likely to be the barrel at fault, or some switch on the gear selector ?
The second thing is the brakes are 'lumpy'. I don't know whether this is 1996 ABS but I can feel movement in the brake pedal even putting slight pressure on the pedal. Pressing hard causes some judder in the steering wheel, although it does stop well. Any thoughts ?
I'll be looking for a garage to sort these out pretty quickly ( I'm thinking Windisor in Chertsey as I'm near Guildford ) and then I intend to start doing some work myself. I'm not 'handy' and I haven't worked on cars before so there'll be questions, questions, questions on here. After searching the forums first of course.
Also, I'll need to tidy up the interior before Mrs New Surf will step foot in it. It must have been sitting around for a while as it smells like old people. Are the recaro seats I've seen in some surfs specific to the Surf ? Can I get them new anywhere or are they only available from breakers ?
Thanks for reading this far.
