How accurate are the temp gauges on surfs? Can you tell from the gauge when it starts to overheat or does it just shoot up and by then its too late?
Temp gauges,accuracy?
It shoots up and is useually too late, i'd reccoment a good aftermarket gauge, there is a "mod" you can do the the original to get it working more accuratly but quite honestly it easier to fit another oneOriginally posted by talisman View PostHow accurate are the temp gauges on surfs? Can you tell from the gauge when it starts to overheat or does it just shoot up and by then its too late?Too young to die and too old to give a toss
temp gauges and senders
As you are in wilts try Merlin Motorsport at Castle Combe they have the gauges adapters and all the ancilaries. their web address is below www.merlinmotorsport.co.ukOriginally posted by talisman View PostAny reccomendations.
If you've got a 2.4 there is usually a spare tapping near where the fan switch screws in to the thermostat housing that you can put the sensor into. You need an adapter (can't remember the thread size) but it saves messing with hosesRoger
Those pod mounts are nice, i fitted most of the gauges in the dash but got one of them for the compas, a row of those pods would look good mounted on the dash top, slight prob running the wireing through tho,
as for gauge reccomendations, TIM are good, just dont go for cheapo chinese $hit, i got a couple for the atf temps and one packed up after a month, look nice but bugger all useToo young to die and too old to give a toss
