I appreciate all the good advice i have received. Generally it seems, those in the know will only pay between £1k and £13k for a minter 2.4. However there seem to be lots of people prepared to pay that and more for trucks that have had no more than general maintenance. Sellers all tend to state that they have had no problems with overheating and oil and coolant levels are fine. From what i have gleaned it is probably better to buy a surf with a replaced head? So would it make sense to only view 2.4 surfs with new heads and any tidy 3L. Im beginning to think 3L is probably better.
2.4 selling prices?
Even the 3lts have some head problems ...... mainly due to lack of air flow or over heating ......... go look for a tidy truck that has not been off roaded and invest in a block tester that will show exhaust gasses in the coolant' You've arrived on a rather special night. It's one of the master's affairs.'
3l is always better, but 2.4 is cheaper. The heads tend to die, but that's pretty common as an engine nears 20 years old. If you buy a 2.4 with the original head, it will be very vulnerable if it gets at all overheated. A 3.0 is more robust, but not totally bulletproof. On the 2.4, it's a design fault. On the 3.0 it's just a factor of age. Don't get too hung up on it, but the 3.0 is a better performer, more reliable and no thirstier, so is the one to go for if you can afford it.Originally posted by talisman View PostI appreciate all the good advice i have received. Generally it seems, those in the know will only pay between £1k and £13k for a minter 2.4. However there seem to be lots of people prepared to pay that and more for trucks that have had no more than general maintenance. Sellers all tend to state that they have had no problems with overheating and oil and coolant levels are fine. From what i have gleaned it is probably better to buy a surf with a replaced head? So would it make sense to only view 2.4 surfs with new heads and any tidy 3L. Im beginning to think 3L is probably better.
