LSD diff
  • LSD diff
    Hi all, silly question but I was under my 1990 G plate Surf today and I spotted a sticker on the back of the diff that said LSD on it. So I am assuming that its got a slippy diff, anyone know if this is correct?
    look on the chassis tag under the bonnet if its got a 5 on the axle code then yes its a limited slip diff.
    www.overfab.uk
      The LSD sticker stands for
      Lysergic Acid Diethylamide
      when adhered to the rear differential
      sorry
      私のホバークラフト は鰻が一杯です。
        Correct.
        Look on the VIN plate on the bulkhead too, if the final drive code ends with a 5 then you have a LSD rear axle.
        Different grade of oil in them by the way.
          Correct.
          thats what i meant cheers vince.
          www.overfab.uk
            sorry
            Changing shocks, buying tools, giving advice and on the look for a compressor.
            3yrs of Surf ownership and you have went from "couldn't put a nut in a monkeys mouth" to almost medicore, amazing what these trucks do to folk.
            A grown up mecano set that you can drive to work
            Brian
              Full service including cam belt, new u joint, centre diff oil seal all this week, not to mention changing the oil cooler, and gear shift cable on my new Transit/
              Somebody stop me >>>>>
              私のホバークラフト は鰻が一杯です。
                Brian
                  I have an LSD. Just thought I'd share that with you.
                  Non intercooled nothing.
                    Lysergic Acid Diethylamide ?
                    私のホバークラフト は鰻が一杯です。
                      Trippy.
                        Ya not alone Gra, I have one too
                        "Cos short cuts cost more in the long run"
                        Buncefield Burner
                          invented by a mr albert hoffman i believe
                            Correct.
                            Does this mean I have rear LSD?
                            Peace
                            cal
                            www.thecellardwellers.co.uk
                              Certainly looks like it.
