Hey guys new to the forum.. basically got a problem.. well aint really a problem just more work than nessary.. basically went to change the oil, and oil filter on my k reg 2.4 auto hilux surf an my friend who was helping jumped straight in under the car with a 14mm spaner and undone a sump plug that is inline with the drivers door and front passenger door (sorry trying to deescribe as best as i can) im guessing this is the autmatic transmission fluid as its pinkish in colour, an seeing that it as quite clean it was not nessary for the oil change! anyway now i just want confirmation that it it the auto box (about 3/4l came out of the sump) and wanted to know where abouts the fill port is for the transmission box (auto) and also going on a search of this forum, dex 3 or 2 is the best to use then cycle the gears with car runnining after change. also wanted to know how to manouver the oil filter (engine) out from the engine bay? is the only way to get it out through the wheel well drivers side? see theres a panal there but bolts are very tight, didnt want to shear them. anyway thanks for the help guys,
low.
low.
