@ Surfenstein
  • @ Surfenstein
    Hi Mark looking for a gearbox for cousin's Diahatsu, Any idea's where we can locate one
    Jess
    "Cos short cuts never work in the long term"
    Buncefield Burner
    ello jess,its quite possible i may have one here,what model has your cousin got, 2.8tdi independant? and dont tell me the layshaft bearings have gone.
    www.overfab.uk
      Don't know much about it, but he explains it's awkward to select 2nd gear at times without "double de clutch" ...
      It's a 1990 2.8 Turbo Fieldman (M75)
      Thanks for ya help ..
      "Cos short cuts never work in the long Term"
      Buncefield Burner
        hi jess. ah yea right, i know what that is,you dont need another gbox, the big flange nut that holds the layshaft in place has come undone and what its doing is when you select second gear its trying to push the layshaft into the transfer case,you need to modify the nut and shaft. if you want we can do it here. the transfer box needs to come off and we can then sort it for you. give me a ring on 07872482076
        www.overfab.uk
          Cheers Mark ya now gotta answer phone message
          "Cos short cut never work in the long Term"
          Buncefield Burner
            cheers jess,i got hold of your cousin and had a quick word.ive left it with denzel to ring him up and see if he wants to book it in.
            www.overfab.uk
              Thanks again for ya help Mark ..
              Buncefield Burner
