Not so sure about the ATF to plump the seals..... i know you can run it as a cleaner but..... Some engine manuals here http://daemon4x4.org/portal/downloads.php but not sure about the Haynes type.. wouldnt mind a link to them if there was...or i could just stop being tight and buy one lol
help needed **urgent**
Originally posted by madcampbell View PostHey Jess I get an insurance advert when I click this ?? ......edit..... the above link changes as the page is refreshed so hit or miss as to getting the link right
http://www.4x4toys.co.uk/ should help
It was there when I previewed it....... before posting !!
"Cos short cuts never work in the long Term"Buncefield Burner
does anyone have a clear pic of which pipe is the fuel return pipe (assuming this goes back to tank) and the fuel leak off pipe (nr injectors) or are these the same thing as i suspect this is the pipe thats leaking as the pump seems dry and the leak seem to be further back.
not sure how relavant it is but somone else mentioned if this was blocked the filler cap would hiss when removed whish it did today but the tank was empty
please help i just dont know what to do and i am running out of time once i have ruled these out i will get a seal kit and attack changing the seals but need the truck heavily over the next few weeks and alot of driving so only have this weekend to sort
cheers guysLast edited by BAV1; 18 February 2010, 22:42.
