While rooting round the back of the truck, solving my blocked rear wash ( stuck ball bearing in a valve) I decided to take off the rear door carpet panel, then a funny shaped black metal cover to see what i could do about the grease that deposits on the window every time i use it. Couldn't really see how thats happening, BUT thought id have a look at the rear demister.
Found the terminal eventually and there doesn't seem to be any loose wire in the vicinity of the spade. ( from what i can see the connection seems intact)
To get a better look, how do i dismantle the door further so i can get at the base area of the glass. ( i could on see this by looking horizontally thru the gaps in the steel panel covering the motor.)
thanks
nigel
thanks
nigel
