Has anyone had any problems regassing the aircon in a 2nd gen? It's working, but was pretty feeble in the summer past and definitely going to want it in good working order where we're going.
Regassing aircon
Originally posted by adpsimpson View PostHas anyone had any problems regassing the aircon in a 2nd gen? It's working, but was pretty feeble in the summer past and definitely going to want it in good working order where we're going.
If it's the original R12 system then it can't (legally) be re-gassed.
This may be helpful
http://www.car-air-conditioning-supplies.com/
Seem to remember there was tonnes of posts about the gas last year, sorry dont have the time to weed through them...at work.............The sh$t gets deeper ...but still swimming
Originally posted by BUSHWHACKER View PostDo you know what type gas is in there now, R12 or R134a?
Don't they recover the old gas and dispose of it properly, vac the system, check for leaks then refill with the newer gas?? Or is it now illegal for them to recover the gas? or cant the old system take the new gas?
Usually a local mobile guy that goes around most areas should be around Ł45-65 I would think. (unless disposing of the old gas costs more)Last edited by rbaz; 2 February 2010, 12:56.
Originally posted by rbaz View PostIf the system is done properly they dont just regas it.
Only if the system has been converted to R134a.
Correct, plus the newer type fittings.
Not if they're a professional outfit, but I doubt any Surfs will still have any of the old gas in their systems, it would have all evaporated by now.
New gas won't work in the old R12 system.
Ł200.
Originally posted by BUSHWHACKER View PostThats just a basic re-gas price. Updating the system costs nearer
Ł200.
Originally posted by adpsimpson View PostNot all good news... How would I find out what gas is in it, whether it's had the conversion, etc? Another unexpected cost if we need to get the conversion done.
It should say on a plate somewhere.
As previously said, if it's 134a then you can buy a can and put it in the low pressure (bigger pipe) yourself.
If it's R12 then you either.
get it converted to 134a (seals oil change etc)
fill it with R12 (if you can find someone with some)
fill it with a 'drop in' replacement (that will work with mineral oil etc)
When adding refrigerant to a system where a leak is suspected then a thorough leak check should be undertaken of the system.
You can do this with the engine off, spray all Air con connections/pipes etc with a soapy water solution.
Of course this check can only be done when there is gas in the system.Last edited by slobodan; 2 February 2010, 15:21.Sent from the iPad you "lost"
Originally posted by slobodan View PostIf it's 134a then they are usually 'push' on type fittings. If it's R12 then it's a 1/4" flare type screw fitting.
It should say on a plate somewhere.Andy
http://www.surfingafrica.net
Try this thread
http://www.hiluxsurf.co.uk/forums/sh...picture&page=2
There are some pictures of an R12 compressor.
I've just been out to have a look but the Surf's not there.
Plavuša always takes the vehicle with the most fuel!Sent from the iPad you "lost"
