Used key to lower back window, loaded up surf with tools jumped in and started it. Pressed button to raise window nothing tried again nothing, jumped out used key in lock window goes up, tried button again nothing. Out come the tools gets meter out and starts to check wiring, an hour and ten minutes later stil no good.
Sits in driver seat, takes a break and rolls a fag, glances at door to see window lock switch pressed down
Depressed window lock button, now works from button fine.
Goes to mum's to do some work, now some of you will recall the fence I demolished a month or so ago.
Well I never repaired it properly, so today I reverse up and starts to unload tools, tool box on to floor, lifts out large box, steps back, trips over tool box stumbles back onto fence. Me and box through fence into rose bush.
Cut ankle, gashed left leg and right inside leg on nails rose bush thorns in hands and left arm. Fence panel now well and truly knackered.
Boy am i glad todays nearly over, just go to over come the stairs to bed and forget today ever happened.
