cruise control question
  • cruise control question
    I dont know if its that i dont know how to use it or if its broke?
    The light comes up on the dash when the button on the steering wheel is pressed, but it wont seem to cruise in a controlled fashion!
    Am I challenged or is it busted??
    I believe that is is factory standard c/c
    I have tried searching but found no answers.
    Ate your buttons on the steering wheel?
    On mine, you press the cruise button, then when you have reached desired speed press set
    Non intercooled nothing.
      Which ones the set button the writings worn off???
        The big button on the left switches the cruise control on.
        On the right are two switches. Probably one is round. The other toggle switch is the resume acceleration/set button. Press the bottom of this toggle switch to set the speed.
          thanks ill give that a try!
            Cadburys Buttons I take it?
              Kraft
                That's right...pick on the bloke with a tiny keyboard.
                  Kraft
                  Somehow, Andy, I just knew you were going to say that!
                    Got away with it. I thought he was going to start on about his
                    "gender realignment".
                      Something else to note, the Cruise Control will not set below 20 mph or above 65 mph. (My speedo under reads so when I set it at a maximum of 65 mph I am actually doing a nice and legal true 70 mph.)
                      Once you have set the speed with the toggle switch you can increase the speed by pushing on the upper part of the toggle... push the lower part to reduce speed.
                      Full details are in the owner’s manual which I’m sure someone will post a link to.
                        Mine sets to 70 mph.... As it was for nearly 12 hours last night.
                          Thanks GWH that was it I tried it on the way home and it made my day!
