OMG!!! Help please...!!!
Bought a 2 year old rad which was advertised as a manual or auto. Guy said that blanking plates would need to be removed if it was to be fitted to an auto.
Spoke to the guy over the phone & he said that the bottom pipes on the rad that connect to the auto box would need to be unscrewed & then the blanking plates could be accessed & drilled out.
Well, got the rad & did as he instructed. Fitted the part & proceeded to flush system with rad flush & clean out. Re-filled system & took for a test run.
Noticed that gear selection was a bit clunky & was suffering a little power loss.
Got truck back home & checked auto oil level.....well I nearly died!! The dip stick is covered in brown gunge which looked like coolant & water & oil all mixed together.
Rang the guy who sold me the rad. He said he would bring another rad over as I collected the rad from his house which is about 14miles.
I'm now unable to drive the truck & have noticed that the gearbox is now leaking this gunge as the coolant must have eaten thriough the gaskets..??
Is my gear box now wrecked?
Any advice much appreciated, cheers all
i have a spare 2.4 gearbox if you have broke it but i suspect it will be fine once it is drained.
