hey guys girls !! can anyone help me with my 94 plate surf ssrx 3.0td manual, its got a button on the transfer box gear stick but it dont seem to do anything, i was told it for the center diff lock but then i told it aint got one !!!! help please lol cheers.
help, with little red button
Originally posted by alexander View Posthey guys girls !! can anyone help me with my 94 plate surf ssrx 3.0td manual, its got a button on the transfer box gear stick but it dont seem to do anything, i was told it for the center diff lock but then i told it aint got one !!!! help please lol cheers.
http://www.hiluxsurf.co.uk/forums/forumdisplay.php?f=34Say not always what you know, but always know what you say.
My 4x4
My choice
Back off
there is no centre diff on a 2nd gen surf.
Your thread is a bit confusing as the title states the red button which is in front of the gear selector but in the thread your on about the button on the ho/lo lever in which that button in for the 4wd in Hi ratio.Do not press it unless you are on slippery or loose ground as these trucks cannot use 4wd on the road unless snow/ice etchttps://www.facebook.com/groups/henpals/
little red button?
Originally posted by alexander View Posthey guys girls !! can anyone help me with my 94 plate surf ssrx 3.0td manual, its got a button on the transfer box gear stick but it dont seem to do anything, i was told it for the center diff lock but then i told it aint got one !!!! help please lol cheers.Last edited by tomtrux; 11 January 2010, 21:13. Reason: people amusing themselves at my expense... not my fault i rambled on at a possible reason for the stupid button!!!!!!!!
Originally posted by tomtrux View Posti had a 2.4 auto surf... the little red button above the transfer lever is to release the gear lever when the truck is turned off!!! take the keys out and it all locks and you wont be able to shift it out or "park" unless you press it. just a safety precaution i think... dont wanna accidentally knock it into gear then try to start it in drive, i imagine a locking method is cheaper than getting the gearbox to not let the engine start if its in gear??? hope this helps
However post 2 kind of covered it all don't you thinkBrian
Originally posted by yoshie View PostIf it had even been close to accurate it might have.
Although, in fact, 'accurate' and 'correct' are not the same thing. Something can be both accurate and wrong if the initial information was incorrect but passed on accurately.
sancho !! it does say 4 wd on it but it dont seem to make any difference, i tried on different surfaces to see if traction changed, pressing the button did not lock any diffs up !!!! how do i find out if it has a diff lock or it has wrong gear knob ???? cheersps are there diff locks on any surfs ???
Originally posted by alexander View Postsancho !! it does say 4 wd on it but it dont seem to make any difference, i tried on different surfaces to see if traction changed, pressing the button did not lock any diffs up !!!! how do i find out if it has a diff lock or it has wrong gear knob ???? cheersps are there diff locks on any surfs ???
