help i have got a 2gen l reg kzn130 3.0 surf with a autogear box falt its not selecting the gear wen in drive low and reverse is ok but 2 is like drive and dose not kick down wen you put your foot down , and wen you put it in drive it sets of like its in 3rd then the o/d light flashes i beleave it goes in to limp mode, the gears do change wen you are drivein but slow , i have had the oil change (dextron3) put in plus had it pluged in and got told it woz the throttle position sensore put that on ,thank you lord lucan 4 it and gess wot no luck 4x4 and o/d work fine eny help ideas you guys help help
auto box help help need help
you need to check the atf level and condition and top up/change if needed.if its still like it after that then theres a number of things.Try dis-connecting the batteries for a while to reset the ecu.
Does the truck go into O.D ok if not then i would say the ecu has probably had it or even the torque converter may of started to failhttps://www.facebook.com/groups/henpals/
Originally posted by stormforce View Postyou need to check the atf level and condition and top up/change if needed.if its still like it after that then theres a number of things.Try dis-connecting the batteries for a while to reset the ecu.
Is there anyone around you with a 3.0l you can test their ecu in yours as i think that may be the problem.I don't think there is anyway of actually testing the t/converter
I know its a bit late but if you still want the sensors i am going to be sorting them this week.They were all working ok when i had the truck runninghttps://www.facebook.com/groups/henpals/
Originally posted by stormforce View PostIs there anyone around you with a 3.0l you can test their ecu in yours as i think that may be the problem.I don't think there is anyway of actually testing the t/converter
Originally posted by iceman View Posthelp i have got a 2gen l reg kzn130 3.0 surf with a autogear box falt its not selecting the gear wen in drive low and reverse is ok but 2 is like drive and dose not kick down wen you put your foot down , and wen you put it in drive it sets of like its in 3rd then the o/d light flashes i beleave it goes in to limp mode, the gears do change wen you are drivein but slow , i have had the oil change (dextron3) put in plus had it pluged in and got told it woz the throttle position sensore put that on ,thank you lord lucan 4 it and gess wot no luck 4x4 and o/d work fine eny help ideas you guys help help
sounds similar to my problem, except i had no o/d light flashing, my solution was gearbox and torque converter from stormy, and now i am having fun in the snow... :P
