Hi I am new to Surfs and yesterday I went to look at a 1995 3.0TD ( 135k Miles) that had been stood for between 1-2 years.
I put a battery on it and fired it up almost straight away but it wouldn't rev.
After looking around all the drive belts where slack
I tightened them up and it runs OK even moved fine the brakes not stuck 4wd engaging ok.
But on the dash the fluid warning light, Tbelt AT light and battery light are on.
Is this probably just the alternator been a bit weak causing the other light to come on or could it have bigger problems? It is charging a little according to the in car gauge but it dips a lot with lights on.
The back door isn't working and it needs rear bumpers but other than usual mess from been stood its in fairly good nick.
Am in 2 minds weather to buy it or not
It has 4 very good Uniroyl road tyres but no MOT Tax etc the owner will not take less than €700 euros for it
I can do all the work myself but don't want it getting expensive.
What do you guys think
) so if its still there this afternoon I will go get it.
He said he had just put a fresh can of diesel in and I will put another in. I did drain the filter to check for water.
I have arranged to go get it and somebody else is supposed to be looking at it but they haven't turned up yet.
