intercooler fitted
like the intercooler
Hi Animal, I've been thinking about putting one on mine. Can you give me some info?
What Intercooler did you use?
Do you have a body or a suspension lift or does it fit witout one?
Does it make much of a difference to the performance? I'm not after a rocket but better exceleration would be good, better fuel economy would be great!“Do or do not... there is no try.”
animal and i are both useing the same intercooler mine came from a pajero 2.5td, i don't think it would fit without a bodylift, performance wise it feels slightly better on acceleration, the main difference i find is up long hills it seems to pull better and the temp gauge don't move now under loadwhen the sh*t hits the fan greet the reaper with a smile
Yeap well worth doing, i used E34 BMW 525 tds intercooler, front mounted in the grill painted black (no bonnet vent), repostioned my air con/extra back up cooling fan, ditched the most of the air con, ditched the 2nd battery (for 1 big better one), air filter behind the headlight (k and N cone), custom pipe run and slightly trimmed the sides of the rad, goes better cleaner, pulls better, tows better, and mine flutters ( can get wastegate chatter, mad for a hilux)
