you're right trev. is it therefore possible to fit the new flashy white / blue thingy and get things calibrated to work....???
does that sound right....??? you know what i mean...!!!
see ya'll
Planty
It should be, but the "fix" installed to get it to display in MPH would need to be removed, then you should be able to swap the faces over.
I am sure one of our experts here can confirm or deny this for you, and hopefully provide a few pointers.
I am sure one of our experts here can confirm or deny this for you, and hopefully provide a few pointers Trev
now that got me thinking......... how does everyones mileage read, in KM or miles....... with the 'fix' in place mine reads in miles....... so, could the speedo simply be re-calibrated to read off the 'new dials'......???
see ya'll
Planty
Hiya Planty,
I have one of the hybrid type speedos that loads of us have here, speed in miles (to 100 mph max) and clocks in kilometres.
So it should be possible to re-calibrate it to read the new dials.
Trev
Most speedos, I would think, are like this.
With Planty's though, his odometer would up until the converstion be reading km and adding it in miles after. This means you would have to be very carefull about the claimed mileage when selling it.
On the gray bike seen there was a unit that you pluged into the speedo wires which converted from kmph to mph. If you have one of these it would just be a case of unplugging it. [I dont know if the speedo is electronic (with wires) or mechanical (rotating cable with gears)]
[SIZE=7][COLOR=YellowGreen][SIZE=5][FONT=Comic Sans MS]The difference between the men and the boys .................... the price of their toys ![/FONT][/SIZE][/COLOR][/SIZE]
If you've been making a lot of calls I don't mind paying a bit more for the gauges - you should not be out of pocket for doing this for all of us.
Ali
Hi. I realize im exreeeeeeeeeeeemely slow on this gauge thing, however, if the whole ordering thing is still going on then i wouldnt mind a set? If im too late then its my own bl@@dy fault.
Here are the latest figures for the Gauges (revised, yes gawd again ), feedback is required from the image posted earlier.
When it comes to ordering they will take credit cards or Paypal folks, further infor on ordering will be posted once we indicate we are happy with the artwork.
3rd Gen are coming on but need 3 more to get out of the blocks, also required is a full instrument cluster - so if any of you guys know of a wrecked 3rd gen grab it's gauges !!!!!
Trev
didn't fieldsy get the clocks when his was wrecked???
like i said... i'll have some as long as the speedo goes to 180MPH
