Are you still doing sports physio stuff?
@Charvell
I can't help with your truck, but, my 'frozen' shoulder is getting on my t1ts!!Originally posted by charvell View Posti am still doing it.. so what have you done? Tony i am going to need the parking switch sorting out on the truck whats it called so i can get some info on it? might see if anyone on here has replaced it..
Do you know of, or can you point me in the direction of any exercises that might free it up a bit.
If I wind a bandage around my upper arm it seems to ease the pain a bit.
Sent from the iPad you "lost"
1st off mate you need to rule out a nerve impingement from the first rib. It is very common to subluxate (partial dislocation) the first rib. this will give the symptoms of a frozon shoulder. A doctor will often mis diagnose this. It is very simple to fix and requires a small manipulation. Go and see an Osteopath or if all else fails a chiropractor.SWIFT AND BOLD
I do have associated chest pain, I don't want to go to an Osteopath, can I self fix?Originally posted by charvell View Post1st off mate you need to rule out a nerve impingement from the first rib. It is very common to subluxate (partial dislocation) the first rib. this will give the symptoms of a frozon shoulder. A doctor will often mis diagnose this. It is very simple to fix and requires a small manipulation. Go and see an Osteopath or if all else fails a chiropractor.Sent from the iPad you "lost"
