Bottom thingy Wheres that then (says the man with no manual) many thanks for your help tho I was clueless
Fuel filter, right hand side of engine bay on the bulk head. On the bottom of this is a tap, wing nut type of plastic nut. Loosen this until fluid runs out, the water should drain out then the diesel, do it up job done.
