Cheap 3rd gen lift kit?
  • #16
    Originally posted by Fernie69 View Post
    So, if we did the suspension and spacers we would get the same lift as the 2 +2 but without the need for the body lift? Mmmm - will ask around. I suppose one of the downsides would be the towball being higher for towing but I could always fit a drop plate.
    I won't be putting the 35's on whatever I decide after what you have advised (and some others) especially as I will be towing. I am listening!!
    Will be in touch...
    Then dont lift more than 4" it wont look as you want it to with 6" lift on 33s
    Brian
    • #17
      Thanks mate,
      As I originally said, I would love the 35's but not prepared to take the massive downside of the gearing problems or the £500 to put it right.
      So, 4" lift it is. Just need to decide what combination.
      Do you want to give me a brief rundown of what you see as the pros and cons of Roughtrax sus kit AND Daystar Spacers OR Roughtrax AND 4Crawler body lift OR Spacers and body.
      I'll ask a question on here too...
      (Can you check email when you have a mo pls?)
      Fernie
      • #18
        [QUOTE=fonecrusher1;596076]Thats not for a 3rd gen.
        You want these; http://www.daystarweb.com/productdet...?productID=537
        2.5 inch lift front & back. I have them on my surf.[/
        I want to lift my 3rd gen cheaply for offroading, I plan to fit 1.5" to 2" body lift along with a daystar coil spacer kit.
        Basically I will be using standard shocks and springs, will the shocks be long enough.
        If not will a 1.5 daystar kit be ok with standard shocks?
        I'm open to opinions and suggestions as to what will work best.
        Thanks
        Anto
