hi all, i am having 4wd problems with my surf, when engaged the rear wheels are locking up and just dragging . is there anyone near the county durham area that could possibly have a quick look for me just to try and diagnose what is actually wrong with it ?
help required please
The two most likley things is a buggered transfer box OR the front diff ......
jack it up , put on axle stands (so all 4 wheels are off the ground)and see if both prop shafts turn , then disconnect the front one and see if the rear then turns whilst in 4wd this will tell if it's the diff or the box
and don't forget to turn the engine off to disconnect the front shaft' You've arrived on a rather special night. It's one of the master's affairs.'
yes bushwacker as if the handbrake is on.
i thought the description was very clear that i was asking someone near by who knows what they are looking at to have a quick look at the surf.
i will jack the vehicle up when it stops raining and post my findings, thanks for the help.
The title wasn't descriptive at all. "Help needed, County Durham area" would have been better.Originally posted by newbie2 View Posti thought the description was very clear that i was asking someone near by who knows what they are looking at to have a quick look at the surf.Do you know that, with a 50 character limit, it's
Transfer case problem then.Originally posted by newbie2 View Postyes bushwacker as if the handbrake is on.
Does the truck free-wheel with the transfer lever in neutral?
I did say to him about posting here to see if anyone can look at his truck for him just to save him a large garage bill
Is it easy to just change the trans box or easier to swap the gearbox with trans box already fitted to it.I only normally sell the whole lot as i can't be bothere to split themhttps://www.facebook.com/groups/henpals/
I saw you saying that Richard, but the title made it look like another question about the problem rather than a request for someone to actually look at it.Originally posted by stormforce View PostI did say to him about posting here to see if anyone can look at his truck for him just to save him a large garage bill
As far as I know, it's a pig to replace the transfer box while the gearbox is fitted.Do you know that, with a 50 character limit, it's
now fixed !! i hope !
hi all, i took the advice and drove the surf over very loose ground today to unwind the transmission and it seems to have worked as the 4wd now works as it should, thanks for the advice guys, just got to get the windscreen demister working now and ill be happy .
