ball joint spacers and diff drop kit
  • ball joint spacers and diff drop kit
    hot off the press,we now have in stock our own patented ball joint spacers and diff drop kits.
    price at £125 for the complete kit plus postage and packing limited supply.
    phone us on 01202 891958.
    www.overfab.uk
    Shouldn't this be in the for sale section??
      possibly vince but i wanted to put it somewhere people would see it,admin please feel free to move if you find it is in the unappropriate place
      www.overfab.uk
        Nice design, cutting the inner edge out. Will save having to grind bits off the wishbone.
        An idea for the spring seats Mark. How about a special set for LC springs where one is half inch thick and the other is standard. Would stop the typical 'Surf Lean' due to the original springs being slightly different lengths.
        I believe coil sprung Range Rovers have the same issue.
          What would be safer, modifying the aloy BJ spacers or grinding down the wishbone?
            Milton Keynes?
              5:45 AM
              Wouldn't have thought either is 'dangerous' as such, but I think I'd rather lose the a few mil of the lip of the steel wishbone than a whole chunk of aluminium spacer. Mark's are steel are they not?
                I believe the reason for grinding the lip off the wishbone, rather than Taking some off the spacers (or making them smaller), Is because the bolt holes thru the spacer are as close to the edge as you would wish to get. Any less metal between edge of bolt hole and edge of spacer would be dangerous, surely!
                Alan
                  the reason for the cut out in the design is to allow for ease of acces to the grease nipple on the ball joint,these were cut from a ball joint template and are an exact replica of the ball joint base.so if you wanted to you can just unbolt and slide the spacers in an out to your exact requirements.and as said before no need to cut the wishbone.
                  www.overfab.uk
                    there will be a slight amount of cutting but not as much as using the big alloy blocks.
                    www.overfab.uk
                      just sent you an email mark if you could reply asap, cheers
                      Completely bitten by the off road bug, and what better vehicle to do it in!
                        Originally posted by surfenstein View Post
                        you wouldnt have to do either with these spacers.
                        Already have aluminium ones in my shed.
                          yep got it mate neil will ring you if he hasnt already.
                          www.overfab.uk
                            cheers bud and thankyou to all you lot who made me choose the ranchos. so i have everything i need. apart from the exhaust is not right
                              so where has everyone that wanted spacers gone.i want some honest opinions now do you think that the products we produce are to expensive?
                              www.overfab.uk
