So this being my first auto gearbox vehicle I'm using the brakes loads more now as I can't slow using the gears and thus am expecting to renew the pads/shoes more often (in theory), have noticed a bit of a squeak noise appear on the first couple of touches of the brake on any given journey and then disappears, the wheels are coated in brake dust and as yet I haven't been able to get rid of it, even soaked them in wheel cleaner and then used a jet wash to try and get rid of it also spraying the calipers (with the jet wash, not the cleaner), but after the jet wash (and a first gingerly trip out) I noticed the squeak went for a few days then came back, so am I getting a rapid build up of dust or could this slight squeak be the first indicators of the pads needing replacement. I can't jack it up here very well because it's loose ground and not level so have been unable to check the pad wear. Gut instinct says dust since the noise went for allmost two weeks after the wash but just curious as to what you guys/gals think.
. I've allways replaced the pads before they get to low so have never heard the niose you get from the indicators but with this one, I can't see the pad wear without taking the wheel off and am worried if I go to a garage with it they'll say "ooooo yeah, big job that, we'll have to replace your entire braking system" lol, you know what I'm getting at.
