Ok computer people ......
  • Ok computer people ......
    ...........need a program to turn pages to a pdf format and then edit and change them .....HELP
    what file type are documents now???
      Sounds like you need Adobe Acrobat.
      If it was just turning pages to PDFs that can be done free, you can get software to print to a pdf file
        could you not use adobe Acrobat? think you have to pay for it!! somwone will be allong with a free one im sure!!
          if i knew file types concerned, i could get ya a program to do it, do you just want to turn a word doc to pdf, or go from pdf to word doc to pdf???
            Print them and use tipp-ex
            Sent from the iPad you "lost"
              I just hope your not refering to the program "pages" which MAC's use...
              Nightmare to convert them to other formats
              If at first you don't succeed, redefine success
                didnt think of that, thats the easiest....
                  Back straight knees bent when pinting
                    Why are you wanting to edit them *after* converting to PDF format?
                      I thought this was a Radiohead thread.
                        Anyway. Edit the document in whatever format it is just now, then print it to a PDF file using using CutePDF.
                          OpenOffice has a native PDF export feature too.
                            What we need it for is to produce a electronic copy of a manual , the only thing is some is in word some is already a pdf file format ,and we need to be able to edit it as the document changes but the end result is a manual in pdf format that can be sent electronicaly or put onto disc
                            I think thats what we are trying to doas i am confusing myself now
                              It is possible to export a PDF to word, but all the formatting is lost (I think!).
                              I have ADOBE Acrobat on my work laptop, I'll check and see what happens to a PDF when ADOBE exports it. Give me a minute or 2!
