couple of manual trans questions
  • couple of manual trans questions
    Just had a call from someone who is having a problem with their 2.4 manual surf.The clutch goes in but it is hard to get the truck into gear.Could this be a clutch fluid problem or clutch itself.
    The next thing is that they have a problem with the brakes.The pedal is hard but nothing happening when pedal is pressed.There is fluid getting to the brake cylinders but the brakes ain't doing anything.Could this be a servo problem or something.I got a brain block at the moment and can't think of what may be the causes.These guys are new members on here but are waiting for their first post to be made live so they can ask the questions themselves.Any help in the meantime so i can ring them back would be great
    If the brakes aren't doing anything could the pistons be seized ?
    Trev
      would the pistons of siezed on all 4 wheels at the same time tho Trev as this is what the guy can't understand.I did suggest bleeding the full braking system and seeing if that made a difference as it would be the cheapest option.
      Any ideas on the clutch prob?
        Re: Brakes. Sounds like a vacuum leak at the servo.
        Re: Clutch, try bleeding the slave cylinder on the bellhousing.
          Cheers me ole mucker
            clutch is either dragging on first motion shaft or centre plate sticking to pressure plate or spigot bearing seizing, brakes i would suggest vacuum pump, hose or servo.
