please give me an answer
  • please give me an answer
    i seem to have 2 egr things on my isuzu both have been disconnected (before i bought it )
    my surf has only one and its still connected
    should i disconnect it and what would be the benefit in doing this .thanks .steve
    the one you need to doisconnect is the one nearest the bulkhead
      That's not the EGR. The EGR assembly is just visible on the right hand edge of that pic. That assembly with the two hoses controls the manifold butterfly.
        Correct. If disconnected, your vision will become blurry the next time you switch the engine off!
          but what does it do and the isuzu has two ?
            What does what do? The EGR assembly?
              yes silly
                Recirculates exhaust gasses into the inlet manifold to reduce the combustion temperatures.
                  http://lmgtfy.com/?q=EGR+valve
                    ok thanks all .not much point in this forum now that google exists is there
                      Are you asking another question or stating an observation?
                        both
                          ok mr google (I THINK HES A BIT OF A BIG HEAD) makes it sound like an important part of the engine but you lot have disconnected yours .so is mr google right or are you
                            disconnected it stops the black smoke u get,or atleast some of it
                              We're right. It is important in some countries, but not the UK.
