Synthetic or Semi ?
    Go on then, who told you that?
    ffs it was just a question.
      Generally, it's the opposite way around. A tad thicker rather than thinner, as the engine wears.
        Aye, ffs, so was mine!
          And a we drop fine sawdust if you're selling it...
            Does that trick still get pulled?
              yes, along with bananas and tights in the diffs
              Sent from the iPad you "lost"
                thank you. that was the kind of answer/correction i was looking for. at least i was on the right track. kinda.
                and yes Albanach, but yours was a sarcastic and belittling question.
                  No it wasn't. I thought your 'Mechanic' had told you that. And sarcasm is not allowed here anymore. It's verbal irony.
                  • #24
                    Re
                    I use 15W40 Mineral in mine!
                    Seems to run a wee bit quieter!
                    Only downside is I need to change it more often!
                    • #25
                      Doesn't seem to matter what you put in - 1000 miles later it's as black as the stuff you drained..
                      Rob.
