am i in 4x4
  • am i in 4x4
    Me again,the plonkar with silly questions
    hows the 2nd gear lever work then,how you know when in 4x4,i thought there would be a dash lite,and do you press the button on side of lever(small one that is)
    my double din stereo not work,do i have to buy another one or can you get a blanking plate and just put a normal one in
    What is the "up idle " button for
    Halfrauds sell a single din size box ,so you can use any regular car stereo.
    Idle up.....increases the idle speed of the engine (obviously) used when running high drain elec appliances e.g. a winch.
    Need someone with an auto to answer the other question.
      to get into 4x4 just press the little button on the side of the "gear lever" the one thats says 4wd and then you are in 4wd high. to put it in to 4wd low just push the gear lever forwards. all the time when in 4wd you should have a green light on dash saying so... DO NOT PUT IN 4WD WHEN ON A HARD SURFACE!!!!..........
      CHEERS JOHN................
        only change from H to L when stationary when you put it into low box, 4wd switches on by itself
          There's a load of stuff in the FAQ on silly questions
          This ones on 4wd http://www.hiluxsurf.co.uk/forums/showthread.php?t=3052&highligh t=wheel+drive
          Rich.
