Back from 3000 stunning miles through Europe without a hiccup (just as well as I left my toolbox at my brother's place as we left...), we drove to B&Q about 2 weeks ago and noticed steam coming out the expansion tank vent.
Reckoned the coolant was low, so decided to do a complete change of that and the engine oil, then while I was at it the ATF, transfer case and front and rear diff oil. All done now and running sweetly, but the coolant took quite a lot of flushing to get the gunk all out...
And of course, when had a look at it 2 days ago, the radiator has sprung a leak. So that explains why the coolant was low, which explains why it was steaming, so that's good. And it also explains the slight peeling paint on the bottom of the radiator.
I've found a reasonably local place that have said they will pressure test the system, find the leak, and repair/recondition the radiator for about £40-£50. Sounds like a good price to me, any reason not to go with it?
Anything else probably won't be to quite the same standard. The Rtrax ones are apparently okay though.
