Fluid advice
  • Fluid advice
    Right, emigrating to Finland at the beginning of October and the Surf's coming too! Due to have a full service done on the V6 in a couple of weeks and I'm after some advice on what fluids for the garage to pour in.
    I'm going to be living in Helsinki with average winter low temperatures of -7C, but with potential to drop to -30/-35C
    Summer temps average 20s with potential of 30C, so similar to the UK.
    So, what oils should I be putting in to cope with the winter, and what's the mixture of anti-freeze?
    1996 VZN185 3.4 V6 SSR-G
    i was going to ask a similar question i want to top up my isuzu with antifreeze coolant iwas told when i bought my surf that the only thing i should ever use was toyota antifreeze / coolant i think it came ready mixed so no water was used . would anyone on here recommend this ?.thanke .steve
      50/50 Anti freeze/Water (soft or Distilled) is the maximum mixture. 100% screen wash and 10/40 semi synthetic engine oil.
        Oil....
        The guys over at ToyotaDiesel have a wealth of info on running in a cold climate - lots of Canadians there. Interesting stuff on block heaters / oil pan heaters / fuel heaters.
        Rob.
          Bullshit. Anti freeze is anti freeze. I use the red stuf from Halfords.
            thanks for that andy
              Mind use the same colour that's in there already though. Unles you flush the system and start afresh.
                Cheers. How about gear and diff oils?
                  http://www.hiluxsurf.co.uk/forums/showthread.php?t=62
