Hi Rich
All home safe and sound, even though we had to use hard shoulder on M5 due to a peculiar burning smell and light smoke in rear view mirror.
Seems the air con tensioner pulley decided to seize solid and smoke was from the belt as it happily polished the pulley
so looks like I'm gonna need a replacement if you have the full set-up lying around including the tensioner bolt and lock nut ?
Was good to see you, Mandy and the mad pirate again, and hopefully next time I'm down work won't interfere with my spare time so much.
If your ever up this way we can always find a bed if needs be
Andy
so looks like I'm gonna need a replacement if you have the full set-up lying around including the tensioner bolt and lock nut ?Was good to see you, Mandy and the mad pirate again, and hopefully next time I'm down work won't interfere with my spare time so much.
Andy
