Can anyone reccomend the best way to extend the fuel filler pipe on the beast.I want to fit the 3" bodylift but need to extend the pipe.Or can anyone reccomend a place to buy the filler pipe.TIA
fuel filler pipe
I remeber you said something about that before Steve.Any instructions on how to fit it to the original pipe thats thereOriginally posted by Phantom View PostWhen you extend the steering use the plastic shroud that your going to remove, it fits a treat.https://www.facebook.com/groups/henpals/
I can't remember how I did it Rich. I had to take it off when I went up to 6 inch. From what I can remember it just went on perfect and was done in about a minuet. When I did the bigger lift I cut the rubber hose and found a piece of steel pipe that fitted inside and just clamped them up. Job done.monstercreations.org.uk
I was thinking of just doing something like that myself.Bit of a dumb question but is it just a short peice of stainless pipe i would need to useOriginally posted by Phantom View PostI can't remember how I did it Rich. I had to take it off when I went up to 6 inch. From what I can remember it just went on perfect and was done in about a minuet. When I did the bigger lift I cut the rubber hose and found a piece of steel pipe that fitted inside and just clamped them up. Job done.https://www.facebook.com/groups/henpals/
