My clutch is sometimes noisy when I hold it down.
Apparently it's a thrust bearing that's not lubricated ?, and it's the one you can't get to without taking the clutch apart/
How much is a mechanic likely to charge for taking the clutch apart and fixing this noise ?
Will I need any bits that need to be replaced when a clutch is removed ?
Is it worth getting the clutch serviced or any parts replaced while it is open ?
