View Post
Hot start problem
Buy a coil marked 'for use with ballast resistor' and should be 9 volt .Buy a ballast resistor and fit this in line before the + terminal on coil . Then a 8 amp or higher wire from the starter (which is only live under cranking) to the + terminal of coil .The connector on starter you need is usually a small Lucas connector or sometimes a bullet type connector .Dont connect to the starter connector for cranking or your starter will not disengage . NOTE : not all starters have the extra terminal you need for 12 volt supply on cranking .
Hope this helps .
My 4Runner uses a ballased system so you could buy a coil and ballast resistor for a Hilux pick up and have some Toyota bits back on it !!Rick...Member of 1st Gen club. ONE LIFE ... GET ONE !!
So just to double check that this is my problem the next time I get it hot and won't start if I connect a fresh battery to the coil and crank it it should start?Originally posted by Vagrant No2 View PostBuy a coil marked 'for use with ballast resistor' and should be 9 volt .Buy a ballast resistor and fit this in line before the + terminal on coil . Then a 8 amp or higher wire from the starter (which is only live under cranking) to the + terminal of coil .The connector on starter you need is usually a small Lucas connector or sometimes a bullet type connector .Dont connect to the starter connector for cranking or your starter will not disengage . NOTE : not all starters have the extra terminal you need for 12 volt supply on cranking .
Hope this helps .
Therefore my battery cranking the engine and a seperate fresh one powering the coil should replicate a jump start?monstercreations.org.uk
