ICE Anyone?
  • ICE Anyone?
    Anyone fitted 3 way component speakers in the front of a Surf? If so, any pics?
    They'll only get wet and not work when you dunk them in the river at Clog.
    Alan
      Fuk I hope not. You should see the pile of stuff I have to fit! Chris will shit himself when he sees it!
        Was originally going to go 3 way with the tweets on the a pillars, 4" midrange in the footwells (DLS Ref 4a still got them new in box) With a 6.5" in the door.
        There was no way the 4" drivers would fit into the kicks, and no way I'd install them in the stock locations.
        Went with 2 way in the end. Am still working on the install. - have fibreglass molded filler bits to block up all the holes in the doors, bought the re-trimming fabric, got all the amps / power cable / distribution etc..done most of the damping.
        Will actually get round to installing in the next month or so (got the split charge sytem to go in as you may well know )
        If you're going 3 way don't even think of going passive - the different positions of each driver will really need an active set up to get each drivers level correct.
        Rob.
          Has this become a Saxo forum all of a sudden??
            Says the geezer rolling on 18's bruvva
              My my Vince, showing your age now?
                Which i where I wanted to put mine! Can't the stock locations be fixed?
                I didn't, but I do now
                Definitely active, got a TRE F-1B
                  I got 6" infinity reference in the doors, will get pics if your interested..?? Paired with a pair of 6x9 infinity reference in a box behind the rear seat, sounds top notch. (also got an 18" sub to 'slip' in when the back is free from crap)
                    sounds good have you got any pics of the rear box with the 6x9s??
                      Mine are all in their original locations n nothing wrong with em...
                      Oh yes, I nearly bought a Corsa !! NOT
                      But I did have a Consul Corsa ir yonks ago, don't spoze that counts tho !!
                      There's always a Payback .... Don't know where n don't know when tho !!!!
                      Buncefield Burner
                        i managed 6 inch 3 ways in dash,original location,didnt do pics,but its a really really tight fit,u need to be good with a dremel,but even then passernger side nearly catches glove box,oh and i also have 6x9s in the rear,in original location,and also 2 12 inch subs,a 100w amp running the 4 normal speakers,and another running the subs,and 2 blue neons that flash to the music
                          Bangin fred homies! Na wheres my baseball 'at!
                            must be in boot of ya ride blood?
                              Bangin fred homies! Na wheres my baseball at!
                              Are you asking if anyones seen your baseball ?
