I was just wondering if anyone has any knowledge of the surf air con? When i switch mine on the electric fans against the air con rad all spin but the air con compressor clutch does not engage. There is no voltage present at the compressor when the air con switch is pushed (although it does light up). Have checked fuses under bonnet but don't appear to be any blown. Is there another fuse box somewhere?
I understand that the ECU won't allow the compresor clutch to engage without the air con system being pressurised to a certain level, is that correct? I have pushed the refill valve in to see if there is any gas in the system. It appears there is, but seems to be at a low pressure.
I also believe that older vehicles (cannot remember the cut off date) can not be refilled with the new gas without (expensive) modification?
Basically trying to find out whether i should just ripp it all out or not. I quite like the 'onboard air' compressor' setup that i have read about on this site.
Anyway hope someone can shed some light, thanks.
