My rear window stopped working the other day, just before I had to pick the wife, daughter and suitcases from the station. Had to put them through the passenger door and over the back seat. The cases, not the ladies. Spent a few hours scrambling about in the back taking connections apart, cleaning, putting back together and retrying with key and inside switch, no joy. Had to put the hedge trimmings in through the sidedoor. Then this morning driving to work thought I would press the down switch and it started working again. Is there a way of checking all the working parts of the rear window mechanism so it doesn't chuck its hand in so regular. Its about the 3rd time I have had to sort it out on the 10 months I have the Surf.
Rear Windows, the ups and downs.
If when it works, it works fine with no problems from the motor, I wouls hazzard a guess that it is indeed a loose connection/poor earth of some type.
There is a relay box that controls the operation of the window, so it's possible that there is a dry joint on the PCB in there.
I'm sure some one with a deeper and more technical knowlege will be along soon to elabourate.
Rob
Still working for the man!
