wireless router
    It should be assigning I.P's via DHCP unless you've cocked about with the settings. Just set it back to DHCP I.P assignment.
      Originally posted by Trinity View Post
      It should sign in with a different ip to the pc automatically
      If you go into the router page in the pc - have a look at the wireless encryption - is it on tkip or aes? - it should be tkip
      ok wheres the router page?(god i love computers)
        its on automatic dhcp????
          What is? Your computer or the router? Set the router to assign I.P's via DHCP and your computer and any other units to get their I.P via DHCP. Don't set static I.P's.
            Go to 192.168.1.1
            On the basic set up page look at the DHCP settings and make sure it's on enable
            On starting ip address put in 192.168.1.100
            Save earth...it's the only planet with chocolate
              the router,only lets me pick automatic dhcp?
                Go to 192.168.1.1
                yep its on enable
                  yep its on enable
                  On advanced routing is the NAT enabled?
                  • #24
                    nothing about nat on there???
                    operating mode gateway tho
                    inerface lan&wireless
                    • #25
                      If you look at the top where it says 'set up' - does it say advanced routing underneath it?
                      • #26
                        theres 2 lines,one white,bottom blue,advanced routing is bottom row far right
                        • #27
                          so click on that and see if nat is enabled
                          • #28
                            it says nothing about nat on there atall?
                            i think if i turn the router on its side it would make good book stop??
                            • #29
                              Lol yes it would
                              Mine is a slightly different model to yours but i thought the set up page was the same
                              Not sure what to suggest without seeing it
                              Re-arranging your room so the ps3 can be connected via ethernet would be easiest!
                              Maybe try ringing Linksys again and telling them it still doesn't work
                              I'm off to play COD4
                              Sorry couldn't be any help
                              • #30
                                Lol yes it would
                                cheers for tryin
