thinking of setting up a switch to enable me to put on the electric fan when stuck in traffic as a just incase measure. i beleave that theres a few of you that have already done this? how did you go about it? ive got a spare hole next to the spot lamps in the middle console there is a coin typey thingy there at the mo. would anybody know where i can get a plain blank switch the same as the others so it would just slot in there???
electric fan
You can get them from Toyota BUT they are PRICEY! Best bet is scrapyard, most toyota switch gear seems to be that size from cars from the 80's onwards so you should find something.Originally posted by slimthinking of setting up a switch to enable me to put on the electric fan when stuck in traffic as a just incase measure. i beleave that theres a few of you that have already done this? how did you go about it? ive got a spare hole next to the spot lamps in the middle console there is a coin typey thingy there at the mo. would anybody know where i can get a plain blank switch the same as the others so it would just slot in there???
I didn't know that the 2.4 has an additional electric cooling fan, the 3.0
has a viscous fan + an air con condenser fan!(well mine has, maybe someone else will put me right if other 3.0 have additional fans!)www.europa88.co.uk Loadsa mods!
You can get them from vehicle wiring products I think.Originally posted by slimthinking of setting up a switch to enable me to put on the electric fan when stuck in traffic as a just incase measure. i beleave that theres a few of you that have already done this? how did you go about it? ive got a spare hole next to the spot lamps in the middle console there is a coin typey thingy there at the mo. would anybody know where i can get a plain blank switch the same as the others so it would just slot in there???
