Any body seen this before, and if so, how do i get round it? PLEASE... Secure Connection Failed
payments.ebay.co.uk uses an invalid security certificate.
The certificate expired on 11/04/2009 00:59.
(Error code: sec_error_expired_certificate)
* This could be a problem with the server's configuration, or it could be someone trying to impersonate the server.
* If you have connected to this server successfully in the past, the error may be temporary, and you can try again later.
Or you can add an exception…
You should not add an exception if you are using an internet connection that you do not trust completely or if you are not used to seeing a warning for this server.
