Brake Spanner
  • Brake Spanner
    I've had a rush of blood to the head and I'm considering fiddling with my brakes ......
    <Cue sucking of teeth & shaking heads>
    Anyway, I'm going to have to spend some pennies on a brake spanner, my guess is that it's going to be metric, 10 or 11 mm, but does anybody know for certain ?
    10mm for the nuts to take the brake line off of the cylinder
      Cheers Richard !
      I've got permission to go for the braided brake lines so I thought I'd change the fluid while I'm at it - although it's dependent on me getting a tax rebate in a few weeks time.
        Originally posted by Predictable Bob View Post
        Cheers Richard !
        Good luck with it.
        The rebate that is.
          10mm All round basically.
          Halfords do one for about £5.
          Good luck dude, dont forget the bleed sequence.
          Alan
            Alan
            That's what gave me the nerve to do it ! It's been about 20 years since I wielded a spanner in anger .......
              TIP, to save the master cylinder seals, after you've opened
              the brake line, keep the brake pedal on the floor with a
              weight, stops fluid dripping, whilst you work on the system,
              then give it a full bleed.
              Oh, dont't forget a pair of MOLE grips to undo the brake nuts
              after they've been rounded off, with your new 10mm spanner
              Gman.
                Gman.
                S'apoint!
                You should use a hydraulic spanner on them brake nuts!!
                  Originally posted by RodLeach View Post
                  S'apoint!
                  Which is what he's going to buy?
                    I'm sure he will, now. (brake pipe spanner)
                      I saw the thread title and thought, 'Here we go again, another one of those special edition Ebay Surfs.'
                        Que ????
                        Can you try that again in a language I understand please Vince ?????
                          Que ????
                          Jack Wolfskin???
                            Do you mean Jack Wolfskin's related to Brake Spanner ??? I reckon you've been drinking more than me !
                              Not unless this is 1995, the last time I got drunk!
