when using 4wd on sand is it best to use high or low, or is there no diffrence??
4wdrive
depends what sort of sand, if its hard, 2WD is enough, if its soft, forget about 4WD and buy a winch.
I'd leave it in 4wd high, unless you get bogged down, then L is easier to pull away as you have more control.4x4toys.co.uk - Keeping you on and off the road...
Originally posted by slimwhen using 4wd on sand is it best to use high or low, or is there no diffrence??
