Nothing to do on nights
    HAVE NO FEAR.. i am back tonight, Tony will have a smoking partner, and you (yeti) can go and fart alone tonight......................
    Working at last.......
      You back ..........that means even less to do .............anyone got a method to dispose of LURCH
        You could make a lift kit out of him
          but it would always be smoking and trying to avoid hard work
            Well seems to me we need a
            "101 uses for lurch".....along the same lines as 101 uses for john major,that private eye used to run
            Suggestion 1.
            put a picture of him above the fire...keep the kids away
            Non intercooled nothing.
              Suggestion 1.
              Suggestion 2.
              Hire him out to churchs and cathedrals as a replacement gargoyle
                Originally posted by UDTrev View Post
                Suggestion 2.
                Suggestion 3.
                get him to place his arms in front of hisself, get bio to turn him uside down and strap him to a forklift and use him as the forks
                  Suggestion 3.
                  Doesn't he have a job working with scaffolding ?
                  As a plank
                  • #24
                    weeeeeel........
                    4th suggestion then,
                    paint him bright yellow and use him as ufo (unidentified fugly object)
                    • #25
                      5th suggestion
                      Strap him to the outside of your 4x4, to use a sand ladder when you get stuck on the Plains
                      • #26
                        suggestion 6
                        coat him in jam and use him as fly paper
                        edit: no need for the jam..........
                        • #27
                          No 7.................
                          place in veg patch to scare off all known pests
                          I've see slugs slither from him
                          Come on 94 to go
                          • #28
                            suggestion 8.
                            Get him to stand still in madame tussaud's ...................and become part of the stock take
                            • #29
                              suggestion 8.
                              He would scare the tourists ........
                              Suggestion 9
                              Place him at engress points for immigrants to scare them off
                              • #30
                                Wahoo...double figures
                                suggestion 10.
                                Dress him in rubber and make him steins slave.....
                                not just at the weekend
