Archie will be shut out
  • Archie will be shut out
    Help please this little fellows arrives soon and the back window is misbahaving, it now will not work from the inside switch and only goes up on the key. If i change the wire going to the motor it will go down. I've swap out the blue control box and the motor but still no joy. Also checked the loom through tailgate all is fine.
    Can anyone give me a clue where to look next
    Thanks Tony
    www.puppywalker.co.uk
    do you have power too and from interior switch.???
    www.overfab.uk
      I have power to and from switch, hoping for a second pair of hands so i can check cable from switch to control box.
        Give the rear wiper a wiggle.
          this may sound stupid but my truck has a window lock switch in the centre consul,if this is pressed in it give the same symptoms as you have described,i dont suppose you have one fitted do you?
          www.overfab.uk
            Window lock on the drivers door but this is off
