ideas please rear tyre mount
  • ideas please rear tyre mount
    Any ideas please will be appreciated with this little problem we have been givent a few suggestions butmore would be welcomed.
    Tow bar fine nice level pull for the caravan there is a spacer been put on no tow bar can't be touched,
    Any ideas on moving the tyre up on the bar a few inches5" for good clearance as the alko stabiliser and the caravan hand break get in the way!!!the hand breke when off is still interfering with the bottom of the tyre
    Have to keep taking the tyre off and then putting it back on when we get to our destination, keep telling the other half he will be getting old soon (now 46!!!!!!)and won't be able to lift it so much!!!!
    we think welding will have to be done and wonder if the top bar can be replaced with a straight one moving the tyre up but have to think about the bottom as that is where it clips onto the car,any one else done this
    Thanks we don't want to sling it underneath love the tyre on the back finishes the car off nicely!!
    Can you not get a plate made up to offset where the spare bolts onto the carrier?
    Locate the plate where the spare bolts are now, with the new location a couple of inches higher
    ....................I-
    ..............___I- new location for spare
    ...........-I
    ............I
    ...........-I bolted to rear carrier
    If you know what I mean...........should be quite easy if you have the means
      ROOFRACK is your alternative to solve your problem i think
        Think someone else had this problem and the simplest solution was to hook up/off at a slight angle to the caravan.
        My 4x4
        My choice
        Back off
          I think the easiest way is to cut and reweld the wheel mounting plate on the arm. Or if you don't fancy that, make a bracket to bolt to the old wheel mounting plate with a new set of studs higher up to mount the wheel on.
          Or buy smaller wheels!
            ...........-I
            ............I
            I think this would be the best way to get round your problem and you would only need to use it when towing.
            I'm a custard donut monster
              can you not retro fit the under floor carrier found on other surfs?
              [FONT=Trebuchet MS][B][SIZE=2]1993 SSR-X 2.4TD[/SIZE][/B][/FONT]
                We thought of that but the inner part of the tyre moulds around a"something" and bolted on!!!! it would have to be cut and rewelded futher up, and ian doesn't think the tyre would sit snug as it does now, hard to explain will take a pic and put on page!!!!! neighbour just caught me taking pics of spare wheel,!! he just saig may be turned tyre around bolt a plate on, higher up andput tyre on other way around,
                Another idea to put to hubby,
                  Making plate to offset and bolting wheel other way round will sort it
                    then the back of the caravan would drag along the road!
                      i think reversing the wheel would look strange, it would stick out and extra 10 inches with a big gap between the wheel and the tailgate, the only real permanant solution is to leave the bar-work as it is, get the pressed steel mounting plate cut off, have a new one fabricated with the modified height, and welded back on.
                      [COLOR=red]Simon [/COLOR] '91 2.4td ssr-x
                        for the amount of time tou tow the cararvan i would either put it in the van or on the roof till you get to your destination. i would leave the surf as it is
                          Is it not possible to modify the caravan rather than the Surf? Can the handbrake be moved out of the way?
