Cant belive it, got the surf back from its recall today, Guess what
they deemed it not road worthy, I dunno why, but heres the list o stuff they picked up on,
1- 3x wipers torn, not a thing wrong with ma front two
2-OSF sidelight,NS headlight,OS brake light all out, I put it in with both sidelights out but both headlights working, so work that one out.
3-Rear number plate lighhts out
4-Timing belt done? Well it was done a ###### year ago, erses just looking for stuff to pick up on
5-Rear wheel arch loose, I.e extended wheel arch is a we bit wobbly.
6-No front Number plate, Well its on the bonnet
7-Brake fluid needs topped up + advised change, Do that when i get extended brake lines
8-Excessive play in NSF wheel bearing
9-Excessive play in NS idler arm
10-Posible leak from steering Box, Possible F**in possible, eiter it is or it isnt FFS, How can it be a possible leak
11-Rear prop rear UTS worn
12- oil needing topped up.
Then to top it off, No road test carried out, not road worthy.
Bonus is, they valeted it, its not been cleaned for more than a month, andd that was only a hose down from Drumclog, cracking job they done o cleaning it thouogh.
4-
4-
