At last
  • #31
    k no worries. Whats an SAS though ?
    • #32
      Tut tut tut Bibs!
      Solid Axle swap..
      Going from wishbones in the Independant front suspension or IFS to a solid axle on leaf springs.
      leaf springs have a lot more flex in them an are easier to carry out larger lifts on.
      • #33
        Originally posted by BioHazard View Post
        Just spent over an hour grinding the bull bar off the pickup .......speak about excessive Arc welding
        comon then ian what you doin
        www.cnpbetterhomes.co.uk
        • #34
          Originally posted by RodLeach View Post
          Tut tut tut Bibs!
          Solid Axle swap..
          Thanks - not goin to be much of th pickup left then.
          • #35
            Thats the plan .......the bodywork is pretty rotten the engine is ok but i need the alternator and the power steering pump all the goodies are spoken for and i'm using the axles so there will not be alot left
            • #36
              One of mine when she was not in retirement
              • #37
                Nay mind - supose it will be worth it.
                • #38
                  What you after .....something to run around in ??
                  • #39
                    Something cheap an chopped that looks a bit mad and it don't matter about trashing it.
                    Keep mine in one piece then.
                    • #40
                      That would be a perfect match for you then Bibs.
                      • #41
                        • #42
                          ive got just the thing for you bibs.
                          www.overfab.uk
                          • #43
                            Now why am I thinking this isn't going to be a sensible answer?
                            • #44
                              It might Diahatsuish!
                              Or a V6 surf!
                              • #45
                                Or the bits off my converted first gen ...........well it's got manual locking hubs
                                Btw need them too
