realy i dont have to stop you guys havant got spear gearboxes you need to sell have you
weird problem!
didnt think of that, thanks i will check.Originally posted by surfenstein View Posti hate to be the bearer of bad news,but if you cant see the leak,just check your rad coolant just in case the heat exchanger has burst and is allowing atf to mix with engine coolant.
the rad looks new, so i wonder if the hoses arnt on propperlyOh Nana, what's my name?
take ur foot off the accellerator and press the button to release 4wd. after about a second or so it will unlcick. do the same to get into 4wd - both when you are moving.Originally posted by steve s View Postrealy i dont have to stop you guys havant got spear gearboxes you need to sell have youOh Nana, what's my name?
think ill put it down to lack of use lol,last i used 4wd was about 15 months ago lolOriginally posted by dieselboy View Posthehe you crazy mofo
30 is ok, ive done that a few times with both my trucks, i think its how you disengage that matters bth. cant remember what the speed limit to do that is though.
i forgot how good 4wd was, in this snow with 4wd on if you are trying to pull away you have about twice as much control over a normal car i reckon.
with 4wd on, breaking, pulling away and turning works better
No you don't have to stop to engage 4wd using the button on the side of the transfer lever, but you DO have to stop if shift the transfer lever into L4.Originally posted by steve s View Postrealy i dont have to stop you guys havant got spear gearboxes you need to sell have you
What's wrong with your gearbox then?
oh and it's spelt spare BTW, unless spear is a make of gearbox I haven't heard of.
yes. should be done every year or so if im not wrong.. dont know anyone who does that though.Originally posted by steve s View Postwell learn sumtin new every day only had my surf about 4 years still better late than never thanks oh and about the gearbox oil change is it a job worth doingOh Nana, what's my name?
hey, thought i would let all know that the truck is all sorted, and going for the MOT tomorrow.
the problem was exactly as i thought - the oil cooler hose had been bodged back on, and was leaking a bit on the return pipe.
so, all new oil and i should have it back tomorrow!
MOTs are expensive now arnt they! i havnt had to pay for one for a few years since my uncle usually paid it for me, but they used to be £35.. now theyre £50!!
when i had that mate it turned out to be my atf pumpOriginally posted by dieselboy View Posthi all, hope you are all enjoying the weather!
i had to drive to work today because there were NIL trains! no bother, 4WD works a charm with ATs
anyhow, i get to the strand and park up, i left it in 4wd as the road had hardly been driven down and wanted to be able to pull away easily.
however, now when i drive, it drives ok, but when i come to a stop it seems to come out of drive although the lever is still in drive..
when this happens, i can press the accelerator and it revs and then all of a sudden goes into drive.
this is very weird. this happens if i am in 4wd or not, and also in 4wd LOW.
i have some theory as to what the problem may be, but im hoping ive given enough info to be told so im not faffin about in the snow (or break down on the way home!)
thanks all!
costly job (well it was for me)am not die lex sick its you that cant read mate
what symptoms did you have?Originally posted by JUDWAK View Postwhen i had that mate it turned out to be my atf pump
im only guessing, but if the ATF pump goes, there is no oil leak, but it wont get into gear because the atf is not getting where it needs to?
i hope having low oil hasnt shortened the life of my pump.
would it have been cheaper for you to source a 2nd hand box?
the bloke who fixed mine said that where someone had put the new radiator on, it had been bodged up with "garden hose" on the atf return.
so bound to work its way out i suppose.Oh Nana, what's my name?
i had the same has you mate
it would just not get a gear for a second then bang
it would just jump into gear
a bit hit and miss like i lost all drive at the end blow the whole gear box cost me over 700 quid dude to fix it in all
i should have had the pump sorted if i had known it was that
i was told so dont quote me
the reverse gear has a spine on it so when you put in it R this spine knocks it in to revrese
my spine had broke off and gone through my pump and knacked the whole thing up
i just carryed on driving
it got worse and worse
untill i had to have a full gearbox recon job done
not bad price realy he did a lot of work and most bit put in was brand new
i did not know then they even had a ATF pump in the gearboxam not die lex sick its you that cant read mate
i didnt either till just now.Originally posted by JUDWAK View Posti did not know then they even had a ATF pump in the gearbox
i'll see how it goes, thanks for the warning.
i dont have £700, so i would have to pass the car on to someone that wanted to take the job on if it came to it :/Oh Nana, what's my name?
took me 12 mounths to find a brave sole that know full well what he was doing
38 years in autoboxes he took some finding i can tell ya
the job he has done is out this world
i dont have 700 quid
but need it again to fix me surf full again
selling me gold its all scrap its what i have collected over the years out of skip hire
now that the skip hire has gone iam skint too allways
