Having spoken to a number of well known 4x4 parts suppliers, I am surprised how negative their responses are towards the Surf
I am also surprised how few actually carry many parts for the Surf compared to other 4x4's that are out there.
I would like to fit some kind of rack/roof rails, and I know lots have done this, but one of the first things is that I was told was that one of the reasons that they don't do much for the Surf when preparing a vehicle for expedition type stuff etc, is that the roof is not strong enough to carry anything!. I know there is no guttering on the Surf, and roof rails /racks can be fitted, but surely the roof isn't that weak - is it? So, how strong is the roof?
Another thing I was told is that the the suspension set up is a major limiting factor, and that you cannot do that much with it! I would also be better off with a vehicle with a solid front axle! I was a bit surprised at this one because having been on this forum, as well as sites in the U.S. and down under, these trucks get put through some real rough stuff - over rocks, through the mucky stuff - with no problems, some even with the standard suspension set up! To me, unless I was to go extreme off road, I would not even consider converting to a solid axle.
I know that many of you give your trucks real use and abuse, and apart from the odd breakage, you have no problems. You also have Bundebashers truck for example, that has been thousands of hard miles overland, fully laden, and again no real problems.
I know we all use a couple of specialist suppliers in Milners and Roughtrax, but why are we only really limited to these, and why do a number of the other suppliers have such a negative opinion of the Surf - or then again am I paranoid?
Cheers, Nick
I am also surprised how few actually carry many parts for the Surf compared to other 4x4's that are out there.I would like to fit some kind of rack/roof rails, and I know lots have done this, but one of the first things is that I was told was that one of the reasons that they don't do much for the Surf when preparing a vehicle for expedition type stuff etc, is that the roof is not strong enough to carry anything!. I know there is no guttering on the Surf, and roof rails /racks can be fitted, but surely the roof isn't that weak - is it? So, how strong is the roof?
Cheers, Nick
the pic that bio put up of the hilux-ish is half way having the cage fabbed up so there is now x bracing and gussets on corners.
